cheesehead
- Sep 14, 2004
Is there an easy way to bypass the windows logon screen?
thanks
thanks
- This is a utility to (re)set the password of any user that has a valid (local) account on your NT system, by modifying the crypted password in the registrys SAM file.
- You do not need to know the old password to set a new one.
- It works offline, that is, you have to shutdown your computer and boot off a floppydisk or CD. The bootdisk includes stuff to access NTFS partitions and scripts to glue the whole thing together.
- Works with syskey (no need to turn it off, but you can if you have lost the key)
- Will detect and offer to unlock locked or disabled out user accounts!
- It is also an almost fully functional registry editor!
