Is that the Phobya Touch 6 controller? How do you like it?
Phobyas website is some flash based rubbish, and the specs I can find on retailers websites is less detailed than I like.
Does it have 4-pin PWM output to the fans? Can you plug in any thermal probe you want? You you ahve lots of control over the fan levels and set points, or is it mostly pre-defined like NZXT's similar touch fan controllers?
Here are some first pics of my brandnew Alphacool Eiswand. It´s a complete set, especially for beginners. I will make some tests with the system later on. Ok now, let´s start with the pics, hope you like them.
And here is a link to an unboxing video from the manufacturer:
Me thinks the pc world has gone RGB crazy. It's a bit much. I like my system to have subtle coloring/LED's. Not what's being dumped out for the sake of joining the RGB craze.
Have you tried the Aurora HardTube LED's with soft tubing? Just curious, but it seems like it might work fine with the correct size.
And what how do you like the Alphacool quick disconnects? I have always wanted a couple in my system for ease loop maintenance and upgrade, and those look pretty nice.
Not yet, but i asked for some samples of those Aurora Leds. I like the full metal Eiszapfen QDCs from Alphacool, they are very similar to the very good Koolance QD3 Series
