How do you change multiple groups of numbers across multiple files.
For ex; I imported 52 worksheets into excel and lets just say each sheet has about 1000 rows with 20 columns. Half of the sheets are full of index numbers and the other half are full of items that reference those numbers.
I need to change about 2000 numbers globally across each of the worksheets like this
5102 --> 25102
5103 --> 25103
5104 --> 25104
With ASAP utilities I can change the numbers globally across each sheet, but as far as I can tell I've only found the option to do it one number a time. If I create a dictionary of what all the number should be changed to, is there a way to batch change them all? With any kind of script or software it doesn't matter.
5102 --> 25102
5103 --> 25103
5104 --> 25104
