I really like the look fo the Bulgin Illuminated Ring Swtiches but they are SP Momentary Contact Swtiches. What would it take to use them as the power switch for running CCL and LEDs for case illumination? A small solenoid?
Thanks.Mohonri said:What you're looking for is a J/K Flip-Flop driving a power transistor. Connect the output of the flipflop to the gate of the transistor (or the base if you're using a BJT) through a 1kOhm resistor. Connect the clock pin of the flipflop through a resistor to 12V, and also connect it to one side of the pushbutton. Connect the other side of the pushbutton to ground.
Thanks for the help. That should do it.Mister X said:Just a reminder that the forum search is your friend.
http://hardforum.com/showthread.php?t=886320&highlight=bulgin
Thank you.cpemma said:There are easier ways.
