Building new for BF1 and WoW...sort of.
Discussion in 'PC Hound System Builder' started by Badcop1124, Dec 9, 2016.
  1. Badcop1124
    Badcop1124 Limp Gawd
    129
    Aug 28, 2008
    Hey all, I been using the rigs in my signature for a while now thanks to the help I got here.
    It seems like it's time move on so I can play BF1. Still play WoW as well.
    Looking at keeping my case, PSU, monitor, mouse, keyboard, Windows 10 and video card (MSI Radeon R9 380 4G).
    This (https://pcpartpicker.com/list/hpZnyf) is what I was thinking of purchasing at my local Micro Center in Cambridge MA:
    Intel i7 6700k
    Gigabyte X170X Ultra Gaming
    Corsair Vengeance 16gb (2x8) DDR4-3000 PC4-2400
    Samsung 850 Evo 500gb
    Obviously RAM will be selected from compatibility list. Would like to keep it at around $700ish. I will probably be doing 2 of these builds.
    Does anyone see any issues (bottlenecking and RAM selection confuses me still) with this build? Better RAM needed?
    Any suggestions on components or anything are greatly appreciated. Hope I posted this in the right section.
    Thanks in advance!
    Edited to include more info.
  2. zpackrat
    zpackrat Gawd
    588
    Jan 28, 2002
    not sure what the Ultra Gaming provides over the Gaming 5, I went with this from MicroCenter
    6700K
    Gigabyte GAz170x Gaming 5
    2 x 8GB Corsair Vengeance 3200Mhz
    Newegg
    Sapphire RX480 Nitro+ 8GB
    Jet.com
    2 x 525GB m.2 Crucial mx300 with coupon 190 to my door
    Personally, I would save the money on the board and upgrade to the 6700k and 390 should be more than enough for 1080 to 1440 with BF1, With my setup I play at 4k with scaling set to 75% and I get 60+ FPS with high to ultra settings.
  3. schlitzbull
    schlitzbull [H]Lite
    106
    Feb 19, 2014
    I would consider grabbing a 2600k/2700k ($150 on ebay) and a new GPU. Or even just start with the CPU and see how your current GPU handles it. What resolution are you playing at? I upgraded my 2500k to a 2700k earlier this year and with my gtx 1080 my WoW minimums were around 55fps at 4k with most of the eye candy turned up.
    vmaddogv and Iching like this.
  4. Badcop1124
    129
    Aug 28, 2008
    Just playing at 1920x1080 on an Acer H233H.
  5. zpackrat
    zpackrat Gawd
    588
    Jan 28, 2002
    I would go for the gaming 5 version of the gigabyte z170x board, at Microcenter it's cheaper and has more, 2 x m.2 instead of 1 is a big one.
  6. Iching
    Iching [H]ard|Gawd
    1,517
    Nov 29, 2008
    But why? It makes no sense. Buy i7-3770 or 2600k, upgrade the video card and monitor to g-sync/freesync. You're still playing on a potato monitor at 60Hz. I second what schlizbull said.
    schlitzbull likes this.
  7. vmaddogv
    vmaddogv [H]Lite
    71
    Mar 9, 2005
    Personally, I just went from a 3550 to 3770k. Made a big difference in frames and I didn't have to swap out ram or mobo. Sandy Bridge is not that old... I would try a proc swap before going all out.
    And I am referring to BF1 specifically. It seems that game takes advantage of an i7 more than maybe others.
    schlitzbull and Iching like this.
