GodOfGaming
- Apr 9, 2012
Hello,
I want to build the ultimate retro PC for gaming. My first PC was with Windows XP, so I've never owned a pre-XP era PC, and now I have a modern PC with core i7 and Windows 7, but I'm not quite satisfied with retro games on this modern PC, no matter how well can features be emulated, I came to the conclusion that to get the best full experience of old retro games, I'm gonna need to build a retro PC.
I guess I should use Windows 98SE or Windows ME as the OS of choice, I think I shall have no problems at all with DOS and Win95 games on a Win98SE machine, right?
I dug around the internet to research the limitations of Win98 and found out that it does not support multithreading, so I guess anything more than a single core CPU would be a waste. It has stability issues with more than 512MB ram, so I guess I should get 2 sticks of 256MB for dual channel. I think it cannot support more than 128GB HDD, so I should probably look for a 120GB HDD. Or is that 128GB partition? If I get, say, 250GB HDD, can I make 2 partitions 120GB each and have no issues? And it doesn't support SATA so everything should be IDE, and it doesn't support PCI Express either.
Now, let me say this, I don't want just a cheap budget retro PC, I want to assemble the ultimate retro PC with all the best parts possible. So don't pay that much attention to the price of parts.
First, choosing the motherboard. As far as I'm aware, AMD single core CPUs outperform Intel single core CPUs, so I guess I should look for AMD. From what I can see, Socket AM2 and Socket 939 have useless PCI Express slots. Then the choice is between Socket A(462) and Socket 754. Probably a bit of a no-brainer, the 754 is newer and should be better. Is there any reason to choose the 462 over the 754? I read somewhere that the best 462 motherboard is DFI LanParty NFII Ultra B, so if you say 462 will be better, I guess I should look for this motherboard. If not, I don't know which is the best 754 motherboard, but I see some guy is selling a Chaintech ZNF3-250 which looks very nice and has 1 AGP slot and 5 PCI slots. Anyhing better than this?
For CPU, I think some old games like Daggerfall and NFS Porsche Unleshed have trouble with CPUs over 2GHz... or is that over 2.1 GHz? I don't know if a 2GHz CPU would be fine, so I guess 1.8 GHz is a safe choice. If going with socket 754, the best 1.8GHz CPU should be Athlon 64 2800+ right? If 2GHz is safe, then Athlon 64 3000+?
For RAM, obviously I should go for a pair of 256MB DDR1 400MHz sticks, right? I have no idea what is the best brand and model though.
For graphics card, I guess the main should be the most powerful one that would work, and I think that's Sapphire HD 4650 AGP, which has Win98 drivers on sapphire's site from what I can see. I also want a graphics card for games that support Glide to get the full enjoyment out of them, is 3dfx Voodoo5 fine, or is there a reason why I should look for one of the older models? Is there another retro graphics card that I might need to experience something in specific?
Sound cards, here it gets interesting, since there doesn't seem to be one ultimate sound card that fits all, looks like I will have to have several different ones for different games. To begin with, Diamond MX300 for games that support A3D. For games that support EAX, what would be the best sound card? Creative SB Audigy ES I think? Though Im not sure if it has Win98 drivers. Or Creative SB Live? I really don't know. I also heard there was a third choice at the time, something called Sensaura, which many different sound cards supported, any details on that? For the oldest games like DOS games what do I need for the best experience, something like Gravis Ultrasound?
For the case I'll choose something modern, with a side panel window so that I can show off the nerdfest inside, not sure what yet, maybe a FD Define R5 or something. I want to use modern 80+ PSU if possible, I don't see a reason why it wouldn't work, but how much watts would I need? 400W enough? I really don't know how much power do these old components suck out.
Finally, monitor, I guess I should find some sort of CRT monitor, those old games work in all sorts of different resolutions but I do think they will end up looking better on a CRT than a LCD. I don't know which CRT monitor to go for though.
Any help and tips highly appreciated! I'm jumping into unknown territiry here...
