Building a LAN party style Minecraft system (20 PCs + server)
Rikki
Hi folks,
Here's an odd one! Been asked to find out what it takes to put together a Minecraft LAN party style setup using 2nd hand lower spec PCs plus a server. Being honest never played it before but the kids its for all seem to be head over heels for it and looking around for what the basic spec is for playing seems to vary a bit.
Has anyone done this and if so what the general PC spec to play and the spec for the server unit itself.
Many thanks,
Rikki
Are they going to be playing vanilla Java-based Minecraft? The new C-based one? Java + mods? Kind of depends a lot on that.
You're going to want to look at quite a bit of RAM on both the clients and the server.
