it really depends on how good you are with routing ittheroam1nggnome said:thank you for the tips on the enclosure, perhaps I will make it in an altoids tin instead of a plastic case
my packages from digi-key and radioshack.com are due to arrive tommorow
cat 5e wire is suitable for wire? and I have like a 2inch strand of it, is that all I need?
I didn't follow the correct layout
