- May 18, 1997
PCPer Buids a Budget PC with the RX 460 as its focus. Our RX 460 review can be found here.
The i3 seems overkill after the Kaby Lake Pentiums for a budget PC. 64$ and you are go for your gaming PC.
Are the KL pentiums out for sale? Looked a day or two ago & couldn't find any on 'egg
As soon as he mentioned a FreeSync monitor the idea of it being a "budget" build jumped off the top floor of the skyscraper. Who in their right mind would honestly spend the $$$ for one for this budget build? Yes he mentioned upgrading and longevity by using the FreeSync monitor but if that was the case there were other bits that could be used to also increase the longevity of the system. But that will also bump this out of the "budget" category.
Also: no OS mentioned at all in the build, that's extra $$$ right there and still not sure why it was left out.
I'm guessing that AMD won't have been too pleased at his choosing an Intel CPU.
He mentioned in the video that they weren't actually available at the time of filming.
I understand why people build PCs for fun.
I understand why people build PCs to accomplish a specific goal or they have niche needs.
Anything else can (from a bang/$ perspective) be done by buying a used pre-built & then updating the graphics card, ram, and ssd and your bang/$ will be much better. Companies that do 3 year leases sell to recyclers that have TONS of stuff for cheap on ebay.
Did you actually watch the video and catch the part where he mentioned that the FreeSync monitor was a huge % of the overall build (~$250, almost 50% as he put it)? And as a reminder, this is tagged as a "budget" build. Again, if you are building a machine that carries a "budget" tag, why add the extra cost of a FreeSync monitor? I'm not seeing this as a machine that *needs* the feature.Freesync monitors are pretty inexpensive so, I am not sure where you get the idea that this would bump it out of the budget category. This is not a Gsync tax after all.
For OS, someone just needs to pick up one of those $10 windows 7 licenses for sale on this forum and upgrade to 10 at will.
I've been looking at a T3600 for my brother in-law and myself. If you can get one with the ~630W PSU, you're set to add any decent video card.
I highly doubt those are valid or legal...For OS, someone just needs to pick up one of those $10 windows 7 licenses for sale on this forum and upgrade to 10 at will.
I'd never ever touch that shit again. Pre-built systems are the worst pieces of crap ever. Even high end ones.Anything else can (from a bang/$ perspective) be done by buying a used pre-built & then updating the graphics card, ram, and ssd and your bang/$ will be much better. Companies that do 3 year leases sell to recyclers that have TONS of stuff for cheap on ebay.
The hundreds of satisfied customers would say otherwise. These are oem keys that were never activated with the computers they originally came with, because the companies just slapped a volume key on them. So they are not associated with any computer yet. I mean one could argue in court that they're not legal because you're not using them with the computer they came with, but I can walk into a store and buy an OEM windows then that's no more legal because it wasn't sold with a PC. I wouldn't use them for a business, but for home use it's all the same. As far as MS is concerned it's a fully legal key that you activate for the first time.I highly doubt those are valid or legal...
Uh, what?I'd never ever touch that shit again. Pre-built systems are the worst pieces of crap ever. Even high end ones.
I just had a choice to build something like this to replace my wife's dead Q8200 based desktop. I considered doing something like that article, but instead picked up an i5-3570 based dell optiplex on ebay for $92 shipped. Added SSD I had sitting around and she has a blazing fast machine for normal desktop usage.
With a $550 budget+$100 windows license, you can easily pick up and i7-3770 for $250'ish on ebay, and have $400 left over to add SSD/memory/graphics.
They have the worst compatibility and the lowest quality parts that are all proprietary, meaning you can't replace them in any case.Uh, what?
In which ways? They get updates & fixes way longer than any consumer level stuff.
Sounds like you got a few bad samples. A bad PSU can happen to non-prebuilts as well. I've used multiple (non hp/dell) video cards in HPs & dells with 0 problems. I've had issues with mobile racks in "standard" atx/eatx cases as well depending what the manufacturer did with the 5.25" slots. The problems you mention are in NO WAY confined to pre-builts.They have the worst compatibility and the lowest quality parts that are all proprietary, meaning you can't replace them in any case.
Unless it's still under warranty and you can get the manufacturer to replace parts in it.
I have a Dell T3500 workstation and it's disgusting. The PSU gives a loud fizzing noise on every startup like it's about to explode, a normal video card just won't fit in the case, and not because of the length. A normal rack also can't be inserted into the 5.25 openings because of the stupid convoluted retaining mechanism designed for nothing but optical drives. Or 3.5 floppy drives in case of the 3.5 slots.
I don't want to be dealing with shit like this for saving a few dimes.
I've had numerous prebuilt PCs go trough my hands from company clearance sales over the years, they all had similar problems. Thanks but no thanks. I'd rather spend an extra $100 and build a proper PC.
Did you actually watch the video and catch the part where he mentioned that the FreeSync monitor was a huge % of the overall build (~$250, almost 50% as he put it)? And as a reminder, this is tagged as a "budget" build. Again, if you are building a machine that carries a "budget" tag, why add the extra cost of a FreeSync monitor? I'm not seeing this as a machine that *needs* the feature.![]()
Building a budget build is far better than buying a OEM machine for personal use. Now, for a business, not so much but, this is about us here, not a business, in my opinion. And yes, you can get a monitor with freesync capability for a pretty inexpensive price overall and it would be worth it in a budget build.
Some people just want a new computer, not a used computer. Our company has only purchased off-lease computers, buying in lots of 100's, and is constantly having to fix things that are breaking. Over the course of about a year, we have collected a pile of probably 50 computers that are NER, and will just be scrapped. New computers would have gone back for warranty service, and probably we wouldn't be dealing with as many failures.
Now, to comment on the PCPer build, a few critiques
1. SSD + HDD - If you are thinking about gaming, then you won't want to load very many games on that SSD, since it will fill up quickly. Then the only speed advantage you will get will be on OS boot up. Unless you want to play "install games only while using, then uninstall when done." Now, I personally have this type of combo, but my main system is not a "budget" build. I'd go for a straight performance based spinner, like the WD Black for a budget gaming build.
2. Case and power supply - a 500W power supply is way overpowered for this build. Sure, if you are looking to put in a video card down the road that would cost more than this system, you'd want more, but a 350W P/S will be more than enough and can be found for about $10 less. Or, my go-to case/PS vendor Inwin has case/PS combo available for about $75 shipped, and has front USB 3.0 ports. This shaves another $20 or so from the price.
3. Monitor - you'd save about $100 not getting a gaming 144hz FreeSync monitor. That would allow you to meet the budget if you had to purchase Windows at full OEM price. However, since this is a bit low-end, the gaming experience could be significantly better with the FreeSync than without.
Agreed 100%. If you want to pick out a motherboard with specific features and be able to slap 10 drives or 2-4 video cards in a machine, you'll never do that with an OEM.
My friend's son who is 13 is waffling on this. He wants to switch from console to pc gaming. He's looked at building an i5-6400 & priced out all the parts he thought were decent & it came up to like $800.
His needs are:
CPU for gaming, videocard for gaming, ssd or two & hard drive or two.
Assuming he doesnt' want to go SLI (he doesn't right now..) he's better off getting something for sub $200 & tossing in the fastest video card he can afford and buying the monitor he wants and using the legal/valid windows COA that comes with the machine.
My experience with T3500 has been exact opposite. As said, you just got a bad sample.They have the worst compatibility and the lowest quality parts that are all proprietary, meaning you can't replace them in any case.
A normal vid card fit just fine. If you call this RX 480 "normal". There is a spot for extra 3.5" HDD at bottom of the optical bay. Mine fit without a hitch. Dell even mounted the screws needed at back of the front plastic bezel. Easy enough to buy $3 adapter and mount another in the 5.25 slot.
Would not hesitate to buy another if the price was right. T3500 is an excellent base for a budget gaming rig in my opinion.
Variations ... the T3400 model - yeah. Very different inside. Would not even attempt a big GPU in one of those. These T3500 are Intel X58 boards, and from what I have seen, perform on par with retail systems running same chipset. They are not going to compare to today's systems, obviously.There are probably various different designs floating around under the same name. This particular model would only fit video cards that have 1 slot coolers. As an office PC dell is OK. But for gaming you can do better, much better, for not much extra cost.
This was the X58 platform T3500. It might perform at the same level, but really the MB has never made more than 1-2% difference in performance ever. So no surprise there. Still I couldn't put even a low-mid level gpu in it without hacking the cooling of the card. This was a few years ago, but I still have access to the PC.Variations ... the T3400 model - yeah. Very different inside. Would not even attempt a big GPU in one of those. These T3500 are Intel X58 boards, and from what I have seen, perform on par with retail systems running same chipset. They are not going to compare to today's systems, obviously.
Interesting. Would appreciate any info you could provide. May receive more of these through same channels I got this one.This was the X58 platform T3500. It might perform at the same level, but really the MB has never made more than 1-2% difference in performance ever. So no surprise there. Still I couldn't put even a low-mid level gpu in it without hacking the cooling of the card. This was a few years ago, but I still have access to the PC.
