EricFX1984
- May 21, 2010
what I have
-a couple hard drives and a 64GB solid state sandforce drive
-power supply (Antec 620watt Neo Eco)
-case
-DVD drive and Blu ray
-Windows 7
-20" Samsung LCD
What I need
-ram
-motherboard and processor
-video card
-true 1080p projector
BUDGET
CHEAP. graphics card under $225, motherboard and CPU both under $300 (as a pair)
YES I will be overclocking. I also would like to buy a CPU that can be unlocked to higher cores if that is still possible
basically I am a HUGE 'Best Bang for Buck' kinda guy
I do not care if it is intel or AMD
If a modern dual core will do the trick then I am open to that even
I mean why get a quad or 6 core if it's going to be a waste of money and energy
I had a Phenom II 555 x2,unlocked to quad @ 3.6Ghz and a gtx460 1GB, this played all my games GREAT...
-case
-Windows 7
-20" Samsung LCD
What I need
-ram
-video card
BUDGET
