Why suggest Storemi and not Primocache ? Because it's free instead of some 10s of $ ? Not even sure Storemi is compatible with Raid. Get the real thing, aka Primocache. And some youtube video suggests it works great with Optane on AMD CPU+MB.Why ECC for a rendering workstation? Note, I am not asking what ECC is or does.
Also, for optane isn't storemi not that great when it comes to caching and he would need to use something like PrimoCache?
Well, it's huge, and the motherboard stays flt aon it... while served with air (and dust) from the top.The Core X9 is so darn great to work with, it's like cheating. Pop the top off and its like an open bench.
I didn't suggest storemi over primocache. In fact I suggested the opposite.Why suggest Storemi and not Primocache ? Because it's free instead of some 10s of $ ? Not even sure Storemi is compatible with Raid. Get the real thing, aka Primocache. And some youtube video suggests it works great with Optane on AMD CPU+MB.
Brand new box of Delta 14mmHg high pressure PWM fans. Loud AF at full throttle but whisper at 500rpm.
So are you putting it one county over or two when you put it under load?
Oh yea, time to finish this up!
I think your gonna "Jizz in my pants" -lonely Island
When you get those dual cards running.
I would love to see some rendering benches that can use SLI. Dont forget your nVlink bridge, they are not included with gpus.
Getting late here but I ran some tspy and fstrike. Darn, just realized it's running ram at 3200 instead of 3600. Oh well will fix it tomorrow.
https://www.3dmark.com/spy/9752103
https://www.3dmark.com/fs/21270633
I am interested in seeing thatHere's to hoping nV actually releases checkerboard rendering soon. I would toss a 2060 alongside my 2080ti so I could get more fps while ray tracing. Let the 60 supplement from behind.
Also your FS score will be low because your not nVLinking your cards. But I think you said you were not going to SLI.
My trusty old EVGA 1200w PS was able to push 2 old Titans in SLI easily, something my Antec 1600w Platinum couldn't do.
Is the EVGA 1600w PS that much better?
I’m still using the EVGA 1200. No more SLI but I do have a [email protected] 2080Ti and 6 hard drives. Takes it all in stride, Best Psu I’ve ever owned. The Antec 1600 Platinum was almost double the price and was junk.I'm guessing guessing you had a multi rail psu then. That has nothing to do with quality but design. Single rail psus like the EVGA G/P/T are great for high power setups where you may not know what your exact power draw per component is. Multi rail psus were kind of popular a few years back but it seems not so much anymore. I gave up on multi rail designs back then since I was a long time quad gpu user/bencher. With multiple high power devices it became a nightmare balancing what when on which rail. And so you'd get rails that were over taxed and rails that were under used, etc etc.
Thanks man. At this point, running a higher all core overclock is possible but the cooling is the limiting factor, that and of course the power draw. In sli on Vray, it was pushing over 1100w, higher at the wall. 24/7 use will be with cpu stock with PBO and the gpus overclocked for the best balance of heat/power vs the cooling on hand.
There is a reason why studios run dedicated 20a circuits as their workload increases.
At some point your single/dual box TR user is going to have to contemplate subpanel upgrades if they go multi gpu or tr4 is 2x what TR3 is.
Storage arrays are easy to take to single phase.
Nah, don't need a 20a circuit. System draw doesn't approach the the limits of 15a.
My apc sua1500 goes into overload status with a single 2080ti and 3960x both at full load (never happens for me out side of load testing). Still works tho. No way I can afford another sua2200, nor do I have room for it.
System doesn't on its own, was thinking NAS and other job flow peripherals.
Add a 2nd box or gpu expand this build with Batt backups for everything.
