i installed front row 1.2.1 on my mac mini, and i have hot corners turned on, and the bottom right corner set to the equivalent of "F11" (desktop expose)
when viewing the "Now Playing" panel in the music section of front row, if i move the mouse down to the corner and activate expose, JUST the status bar (with the time and volume) disappears. i can still fully control front row, either via my keyboard, or my MX700 mouse (Set up using USB Overdrive).
the funny thing is though, if i move it to the corner that is the quiv of "F9" (all applications expose) the bar disappears, but instead of FR continuing as usual (minus status bar of course) a hand pointer (the same as doing expose normally) appears, and FR is not controllable
weird, i like it...makes the FR interface cleaner without the bar there
just thought id throw that out there, oh and if your running a legit (read: supported, as in you have an imac or intel mac mini with it) version of FR, would you mind confirming this is a front row thing, and not just a quirk with my mini?
