For those who have successfully flashed your Buffalo routers to DD-WRT, please chime in. I decided to flash my wireless router (WHR-HP-G54) to DD-WRT since the stock firmware is annoying the hell outta me. I already read the wiki link for the installation: http://www.dd-wrt.com/wiki/index.php/Installation#TFTP_Flashing_Buffalo_Routers_under_Windows but for step 4, there are different approaches for loading the new firmware and its like trial and error!
i.e. first approach is to hit enter to start TFTP transfer then immediately connect power to the router.
Another approach is to plug in the power cable first, wait a few seconds until the red DIAG light comes on then press enter to start the TFTP transfer.
Which method did it work for you?
Also, do you leave the cable modem ON and connected when you do the above procedure?
For the stock firmware, my computer gets a different IP whenever the cable modem is turned off and on again. I am wondering if its the same for DD-WRT or does it use a fixed IP everytime?
Thanks in advance.
Thanks in advance.
