I have a 5870 and some other spare parts around. Want to build a backup computer that will eventually replace my P4 HTPC system.(when I get around to buying a tv,stuck with s-video for now) This will not be my main computer. It will be in other room,I will occasionally use it to game and watch tv,netflix.
I will be moving around sometimes to different parts of house. If I could find a case that can sit vertical or horizontal it would be nice.
I also wouldn't mind getting a cheap or recertified prebuilt Dell or something and putting my power supply and video card in it if it will save me money on os and stuff.
htpc,tv tuner and light gaming(gta 4)
$300 to $500 kind of open here. The cheaper I can build it the sooner I can buy the parts. I don't want to spent too much all at once. I can wait for deals to come along if I know what i am looking for. I could spend $300 and put it together now.
Boston Massachusetts USA. I live near a Microcenter.
Motherboard,cpu,ram,hard drive,operating system and considering a case.
I have a ide dvd burner,Antec NEO ECO 620C 620W,ati 5870 referance video card and dell 2350 case.
6) Will you be overclocking?
No overclocking.
1080 tv
Over the next few months but I don't need it.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Onboard Video and WIFI would be a plus but I don't need them.
I don't have a os. I had Vista but I used it to upgrade to Windows 8, I guessing I can't use it now on another computer.
This is what I come up with but I am not up with the latest things. I used parts from Logan's $550 build.
Case. I have a old Dell 2350 case I can use or I would need htpc case that can lay on side or stand up. So it will fit under tv 8.1/4" to fit tv stand,would also like to stand upright in other room.(I can do without this or get one later)
Power supply. I have a Antec NEO ECO 620C 620W
Video card. Have a referance xfx 5870 xxx edition (almost 11.5" long)
CPU- CPU: AMD Phenom II X4 955 Black 3.2GHz Quad-Core Processor about $91 shipped http://www.ebay.com/itm/New-AMD-Phe...BOX-/200880572604?pt=CPUs&hash=item2ec56a48bc
Motherboard- ASRock 960GM/U3S3 FX Micro ATX AM3+ Motherboard. About $62.00 http://www.newegg.com/Product/Product.aspx?Item=N82E16813157323
Ram- G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9D-8GBXL about $50.00
Hard drive- Storage: Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard. about 57.00 Drivehttp://www.microcenter.com/product/399209/Barracuda_500GB_7,200_RPM_SATA_60Gb-s_35_Internal_Hard_Drive_ST500DM002_-_Bare_Drive
Windows 8 about $100- http://www.amazon.com/Windows-System-Builder-DVD-64-Bit/dp/B0094NY3R0 ( I think this is full install and not upgrade)
Total about $370.00
Did I forget anything? Thanks Tom
No overclocking.
1080 tv
Total about $370.00
