6) Will you be overclocking?
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
What I've been looking at is picking up the following:
I prefer quad core which is why I choose the i5-3570K. Wasn't too sure about the GPU, the 650's seemed like they couldn't really handle max settings on games based on a couple reviews I read and the 660ti seemed a bit out of budget when comparing it just the regular 660. Nvidia gpus are preferred over AMD mainly because of Physx and good drivers. Didn't really dabble into AMD processors as I am not familiar with them much. Thoughts and recommendations?
- Gaming on high settings and web browsing
- Around $650, Yes
- 90815
CPU, Mobo, GPU
- Cooler Master Stacker 832
- Corsair AX1200
- G.Skill Ripjaw Z 16GB (4 dimms, 1600mhz)
- WD Black 2TB
- I also have a Gigabyte x79 UD5 mobo and have debated using that
- No
- 1920x1080, 22"
- Within the next month
- USB 3.0, SATA 6Gb/s, 4 dimm slots
- Windows 7 64bit Pro
- Ivy Bridge i5-3570K (room to overclock later)
- ASRock Z77 Pro3
- EVGA SC GTX 660 2GB
