As of now, I use a 2.26 GHz P4 with 512 MB RAM and an AGP GeForce 4 Ti 4200 (64 MB) card.
I use my computer primarily for 3d modelling and rendering, and it works...but I would like to increase performance, mainly rendering performance and responsiveness in opengl of large scenes.
I'm planning to get a new processor, motherboard, more ram, and possibly new video card...with emphasis on lots of RAM and a good processor.
My requirements for myself so far are:
Processor Reqs
* 2x 64KB L1 cache
* 2x 1 MB L2 cache
* 2.2 GHz clock speed
* Dual-Core
* 64 bit
* Max of $600
Motherboard Reqs
* 4x USB ports
- 4 GB memory support
- 1 AGP slot (for GeForce 4)
- Fits processor Socket type
- Dual-Core compatible
* As long as it has 4 USB ports and is compatible with everything without causing a bottleneck, I am happy
* Price range: like to spend $80, absolute max of $200
Memory Reqs
* 4 GB DDR
* Approx $400 total
* Quantity is much more important than quality, since I don't want to go over my price limit and chances are I will still not have enough RAM and will end up using virtual memory, and that's going to make a much bigger difference than the speed diff between the newest kind of RAM.
Video Card
* Under $200
* Be able to display significantly more vertices/faces than my current card
* Any other special features useful for games etc are irrelevent to me
So, I am considering:
1) $570 AMD Athlon 64 X2 4400+ Toledo 1GHz FSB Socket 939 Dual Core
2) Can't find a motherboard that meets requirements
3) $74 eVGA 256-A8-N341-LX Geforce 6200 256MB DDR AGP 4X/8X Video Card
4) Memory dependent on motherboard
What do you think about my choices?
How much improvement can I expect from this video card?
Any suggestions for a motherboard?
Thanks!
Processor Reqs
* 2x 64KB L1 cache
* 2x 1 MB L2 cache
* Dual-Core
* 64 bit
* Max of $600
Motherboard Reqs
* 4x USB ports
Memory Reqs
* 4 GB DDR
* Approx $400 total
Video Card
* Under $200
Thanks!
