Doing a budget build. Not having any problems with it, but wanted to get some other opinions for a change. Mainly just bored and wanted to see if anyone else has some ideas different from my own.
Need motherboard, CPU, and RAM for $320 max. Money is an issue, so cheaper is better. Longevity is key here since this person will probably want to keep using this for the next 10 years.
1. Total - $313 (+ $10 MIR)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.500642
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145251
2. Total - $295 (+ $15 MIR)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103703
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.492651
3. Total - $293 (+ $15 MIR)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103699
Other notes:
- I would consider going with an Intel build if it offers better performance at the price. I can't come up with any Intel build that comes close however.
- If using AMD, I have a used Scythe Infinity or an unused Phenom II 955 heatsink/fan that I can use in the build.
- Will be using a used SilverStone Zeus ST85ZF 850W PSU. This is the Etasis built model.
- Will be using an old generic mid tower.
- Will be using a leftover Windows Vista Ultimate x64 license that I have.
- Need to get an optical drive and hard drive. Plan on purchasing these, for a grand total of a $390 budget (figuring $10 shipping will hit the real max of $400).
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136074
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118039
EDIT: Also, gaming, unlocking, and overclocking are not in consideration for this build.
Other notes:
