Watching movies, photo editing (photoshop), web browsing, basic stuff
$700-800
3) Where do you live?
Los Angeles, CA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
CPU, Motherboard, RAM, PSU, HDD, Burner, Case, MONITOR
None, completely new
6) Will you be overclocking?
No
Need 24"-27", at least 24"
Now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
No Crossfire or SLI, no RAID
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Yes, have OS, Windows 7 64 bit Ultimate
Hi guys, friend needs a budget productivity machine, he has no plans to do gaming. The firm budget is $700-800 but since he doesn't want to do gaming, I'm hoping I can get him the machine for pretty cheap and leave the rest for a nice monitor.
To start off the build, I was thinking of going AMD with this CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
Also, HDD needs to be 2TB.
Any recommendations? Danny? =p
Thanks for your time!
$700-800
Los Angeles, CA
No
Now
