]|[ Mar']['in ]|[
- Sep 20, 2002
Check to be sure you have adequate disk space. If a driver is identified in the stop messages, disabled the driver or check with the manufacturere for driver updates. Try chaning video adapters. Check with your hardware vendor for any BIOS updates (disable BIOS memeory options such as catching or shadowing...blah blah blah
So I have 2 of the exact same computer, one of which I'm posting from, the other useless because of this error.
It's an albatron mobo with onboard everything (including mx440) with 512mb of pc2700 ram and 1700+ proc.
Any ideas here? I don't get why one worked flawlessly and the other after I went through the formatting the hard drive process gets an error.
