Try an IceMat. You can get them at Performance PCs. I've had one since 2006 and stilll has not warn out. it actually gets smoother! It will wear out the pads on the mouse before you wear the IceMat out. It's made of a frosted glass, and is extremely tough.
if you want the slickness of a hard pad but also want some extra durability instead of developing flat spots too soon etc then you should inverst on a artisan hien - HARD thickness from amazon, avago 9500 sensor track fine on them too, they're not your ordinary cloth pads
I'm telling you. An IceMat is the way to go if you want durability. They are plenty slick and I've had mine for years. I don't plan on replacing it any time soon! And if it's not slick enough, then clean it with some of the Teflon tile cleaner for bathrooms. I'm not sure if it good for you skin to be resting on it, but I did it one it was like oil!
