Borked nvidia driver.
c3k
361.82 (hotfix) is out. It seems that the previous driver in Windows 10 caused a W10 to look at the gpu as an ejectable media. I did not try to eject my video card. I don't think anything good would've happened. Perhaps an [H] member could do the experiment?
361.82 fixes the issue.
361.75 was the bad one.
I tried it, the screen goes black for a couple seconds and then comes back. Nothing bad happens.
It's just about the same as going into the device manager and disabling the GPU.
Thanks for trying it. I figured, with my luck, it'd give me a black screen and I'd have to pull my card and try another or the iGPU.
Ken
