Kramerican
- Apr 25, 2007
Using a dual boot with Vista 32 and XP. Getting an error when trying to boot.
When I attemp to boot XP I get this screen...
When attempting to boot Vista I end up with a screen saying this...
I tried the repair but with no luck.
Code:
We appologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this.
If your Computer stopped responding, restarted unexpectedly, or was automatically shut down to protect your files and folders, choose last known good configuration to revert the most recent settings that worked.
If a previous startup attempt was interrupted due to a power failure or because the power or reset button was pressed, or if you aren't sure what caused the problem, choose start Windows normally.
[COLOR="Yellow"]Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Last Known Good Configuration
Start Windows Normally[/COLOR]
Code:
Windows failed to start. A recent hardware or software change might be the cause, To fix the problem:
1. Insert your Windows installation disc and restart your computer.
2. Choose your language settings and click "next".
3. Click "repair your computer".
If you do not have this disc, contact your system administrator or computer manufacturer for assistance.
File: \Windows\system32\winload.exe
Status: 0xc000000f
Info: The selected entry could not be loaded because the application is missing or corrupt.
