This new Shuttle XPC based project was kindly sponsored by Modaholic.com. The bulk of the worklog will be featured on thier new site in the coming weeks.
Modaholic.com provided a brand new Athlon 64 Shuttle XPC and Athlon 64 Winchester CPU.
This Project began life in the pages of my sketchbooks. It was keeping the
Satan's Deuce project company for a long time. Now out of spite it has been bugging the crap out of me to be built also.
This will be the 3rd Shuttle I have built and this one is the most complex of the 3
It has some very nice lines and these flip down doors are really sleek.
Throughout this project i will be showing the original drawing with red outlines around the various parts of the case. These will coincide with the images of each part as it is being constructed.
The main engine body is a plywood box that has been covered in foam and fiberglass, filled and sanded smooth in a lathe. The shuttle chassis is housed here.
One of the ideas for this mod is to create a contrast between the base/stand and the actual turbine. The Turbine will be finished with automotive paint and clearcoat. the stand and base are made from various woods and plastics and will be finished in traditional furniture finishing techniques. The wood and painted surface of the turbine should create a very complimentary contrast when viewed as a whole.
The base is made from black Walnut. This wood is very special, it is over 300 years old. The top of the base plate is a single 14"wide 1" thick board, the tree it was cut from was massive to yield a clean, sapwood-free board this size.
Normally large planks are made by gluing smaller strips of wood together to form a wide plank ( like a table top), however the major drawback to this is the grain of the various boards does not line up or match and visible lines appear where the joints are. Boards of this width are very scarce, usually wide boards can suffer from warping if not dried or stored properly, which makes them even harder to find in usable condition.
The base plate is tapered from front to back. the front is 2" thick narrowing to 1" thick in the back. The top was cut out and inlayed to create the design you see in the photos. The base is 25" long and 14" wide.
The edges of the plank were cut down to 45 degrees with a router then shaped with handtools and sandpaper into gentle rounded edges.
