Bluetooth keyboard/ silent-click mouse
SJJ
I'm searching for a keyboard and mouse combo with Bluetooth connectivity and where the mouse is 'silent-click'. Any suggestions?
I can find these things individually but would prefer to get as a combined set to 'ensure' compatibility and maybe save some $$$ too.
doubletake
If you're going for BT connectivity, that right there is your compatibility layer, unless you dont have built in BT on the computer and are relying on them including a wireless adapter.
rhkcommander959
Do you want a real keyboard layout or a portable solution?
I've had this for years, quiet and reliable but it's not fun to type on at length:
Mini Keyboard,Rii X8 Portable 2.4GHz Mini Wireless Keyboard Controller with Touchpad Mouse Combo,8 Colors RGB Backlit,Rechargeable Li-ion Battery for Google Android TV Box, PS3, PC, Pad,Nvidia Shield https://a.co/1RLTBvm
I've used it with my phone plenty, especially when using my phone to play videos on tv/projectors.
SJJ
Sorry, by 'ensure capability' I meant between the keyboard and mouse, i.e. if they're the same brand they're likely to work well together. I'm pretty confident different brands of each would still work as it's more about each device's BT connection to the laptop...so yeah I guess it doesn't have to be the same brand for both devices.
SJJ
Thanks for the link - an interesting looking device which I've not seen before. That said, I'm looking for a real keyboard as it's for work purposes.
Since my original post I've found these two items which are definitely suitable / great but are also pricy so I'm open to hearing about other options.
Logitech MX Keys (keyboard)
https://www.jbhifi.com.au/products/logitech-mx-keys-advanced-wireless-illuminated-keyboard
Logitech Master 3S (mouse)
https://www.jbhifi.com.au/products/logitech-mx-master-3s-performance-wireless-mouse-graphite
