Bluescreen Tuesday (Help)
oplin
We have a computer here where when we got in was in the windows recovery console from blue screening after the windows update. So we did a System Restore to before the point that never finished and now can't even get the windows boot menu to show up. From reading around you aren't supposed to do a system restore after failed windows update. Anyone have experience with this. Working on running checkdisk now. Looks like the machine might be hosed. Does anyone know if you can do an install over the copy of windows and keep everything? In windows xp I was pretty sure you could do the reinstall where it would copy all the system files over it, then do updates and it cleaned out almost anything that messed windows up.
Thanks
