Phandalyon
Guest
- Jun 12, 2001
Alright. In the middle of December I got the parts for this computer and put it together. Everything ran OK during install. Finally I got Windows up and drivers installed and started running PRIME95 to do a quick stresstest. Bluescreen.
Anyway, long story whort, I replaced the motherboard. When that didn't fix it I replaced the CPU and RAM. I finally got all the parts and got it back up and running yesterday. It will run Prime95 for about 5 minutes then bluescreen. It first crashed on a file called sfng32.sys, which it seems a lot of people think is Skype. I can tell you with complete assurance it is not since this is a completely fresh windows install and I have never even downloaded Skype. Anyway, it seems the files are part of the onboard audio, so I disabled onboard audio and uninstalled all of the drivers and files for it.
Ran Prime95 again, system is still crashing. Blue screen about 5 minutes in. This time though it is just a STOP error. I am currently doing BIOS updates on the new Motherboard (did them on the old one) and updating all the drivers to be sure. BUt any other ideas on this one?
System specs:
Intel DP965LT motherboard
Intel Core2 Duo E6300
2GB OCZ DDR2 (2x1GB)
Seagate Barracude 7200.10 250GB SATA2
LIteon DVDRW
Mitsumi FDD with card reader
Antec SP-500 500W modular PSU
ATI FIreGL V3100 PCIe 128MB Video
The computer ran overnight last night with no load with no issues. But when the system is put under load it crashes.
I will get temps in a few minutes once I have the software installed.
System specs:
LIteon DVDRW
