That is a pretty odd form-factor. I think my Alienware laptop is the only PC I've ever owned with an extra slot for one of those cards...
Wait... I have a Dell Hybrid PC that has a blu-ray decoder built-in. That must be what they're used for that. Maybe I should open it up and have a look.
The Broadcom Crystal HD decoder is basically that. Its pretty cheap too:
http://www.newegg.com/Product/Product.aspx?Item=N82E16816321016
The only drawback is that it uses Mini PCI-Express, you'd need to use an adapter to use it inside a PC unless your motherboard has one. A company called HWTools sells them.
http://www.hwtools.net/Adapter.html
http://www.hwtools.net/Adapter/MP1.html
