Tech-Daddy
- Jul 28, 2004
I just copied and pasted my post in the sticky, so apologies for the redundancy.
Let me know what you think!!!
-TD
Doing touchup painting to it over the next 24 hrs, hoping to land in the BYOC @ Quakecon. Here is the rig:
This first one shows the flame cuts on the window, it was a test fit that I did prior to compled painting of the base, and the spacers for the 5.25 and 3.5 locations
The inside of the case is a anodized green metalflake finish with crushed velvet material:
The top has same style harloquin flame cut, but in the inverse of the window. I mounted a heavily sanded piece of plexi under it, then lit it with the case colors from opposing ends:
Close up of the flame on top:
Closeup of the window,
Looking up into the power supply:
The rear of the unit:
Front, 3/4:
Still have a little touch up to do, and I have an idea that I will experiment with tomorrow that might pop the flames in the dark! Thanks for looking! See y'all @ QC!!!
-TD
Front, 3/4:
