http://valid.x86-secret.com/show_oc.php?id=186591
http://valid.x86-secret.com/show_oc?id=114166
http://valid.x86-secret.com/show_oc?id=132953
http://valid.x86-secret.com/show_oc?id=132951
Further testing reveals I hit a wall at the same place my 90nm did vs the 65nm. I haven't gotten the chance to post that.
However... my NF-M2 doesn't have a FSB limit that low, its max CPU FSB is 370FSB, no matter the setting 2 cpus will not break over 3ghz when hit, they give off a odd Blue screen with no data on it at all. I would post 3015mhz speeds but it blue screens after about 3 secs as in blank blue. No error explination, most of the time I don't even have enough time to valitade it.
The same thing happens on a Tforce-6100-AM2. 2 unlucky cpus both tested on different systems. Kind of strange. I tried onboard and PCI-E. Both give me the same results.
So it maybe some settings I am missing here... such that might have to do with USB IDE or SATA failing over those speeds somehow. I don't get why they both max out at the same speed and get the same strange effect. Overvolting further doesn't help, lowering HTL
s to 1x doesn't help, infact gives a worse OC for the 65nm on BIOS12. BIOS13 fixed a lot of limits. However I am puzzled how ppl are getting above 3ghz on NF-M2's.
K8's max is most of the time 3ghz on AM2 not 939, however F3 and G1 fixes this for 99% of the ppl giving 939 OC's. But It puzzles me I can max out on the same speed on 2 diff cpus with 2 diff mobos.
