Moogle Stiltzkin
- Nov 11, 2004
Chapter 2. Medical Pavilion
Ok so, i reached the first Gatherer's Garden after i saved the Little Sister since i'm merciful *this is near the very end of Chapter 2. Medival Pavilion.
I buy the plasmids but then run out of slots.
So how on earth do i change to another Plasmid i had earlier ????
The answer is the Gene Bank which is available in the next chapter after this one.
Chapter 3. Neptune's Bounty
The first Gene Bank you find is at the begining of Neptune's Bounty.
Anyway i hope that clears some questions everyone was asking about how to switch to other plasmids that aren't in a slot, and how to get more slots for them
Plasmid/Tonic FAQ
http://www.gamefaqs.com/computer/doswin/file/924919/49886
BioShock Walkthrough Guide
http://www.gamefaqs.com/computer/doswin/file/924919/49919
Trainer
*Get this from Cheat Happens website :x
each gatherer's garden seems to have a set selection of stuff you can buy from it, so you will only be able to buy extra slots when you find the appropriate gatherer's garden.
The 2nd area - Neptunes Bounty has a Gatherer's Garden where you can buy an extra plasmid slot.
then you are able to buy plasmid slots for 100 ADAM. You may have to have harvested/saved 3 or more little sisters.
yeah went back and found. its just called plasmid slot, and its at the top.
Plasmid/Tonic FAQ
Trainer
