Formula.350
- Sep 30, 2011
Prior to 1.72, the things that have been there, but non-functional that I've found, have been: CPU VDDP, and SubTimings. BCLK works, albeit in the limited capacity it is able due to a lack of hardware. Meaning you have: 100, 101, 102, 103 and that's it. 100 seems to run much closer to 100MHz than "Auto" does (99.8MHz), where as 103 for me has seemed to result in the SATA controller flaking out which causes a Windows BootLoader error OR no POST. 101 and 102 have worked just fine though, which while not much, at least bumps the memory up a tiny bit more to just shy of 3300MHz.Okay but how much of the hidden stuff is actually working , it is nice you can put values to things you want to change but if nothing happens.
BUT on the flip side... beings we're months into Ryzen, new settings even if unavailable w/o modding, is a good sign. It means we'll eventually (hopefully) see them added, or at the very least it shows us they're TRYING to add new features.
Nevertheless, I'm too eager to flash this thing, so I'm just going to change all the SubTiming's "View Access" to USER and dig into this puppy!
UPDATE: Alright so first things first... Flashed, rebooted, configured fans (I suspect my modding BIOSes results in the OC Profiles failing to apply, no biggie). Set DDR4-3200 (it does indeed list DDR4-4000 now!), set timing to 15-15-15-35 1T, set DRAM to 1.35V, saved and booted to Windows. (Not abnormal for my system to post perfectly fine at 3200 the first change after a BIOS Flash).
Right out of the gate, what's worth mentioning? I set the timings to 15-15-15-35 and CPU-Z reports it's RUNNING at 15-15-15-35!
Time to run some tests...
