Evga released a bios update for their Superclocked versions
http://www.evga.com/support/drivers/default.asp?switch=2
The direct link to the page gets a can't find drivers so you have to find them manually on the page but its under Download Drivers --> Geforce 8 series --> Bios Update
Anybody want to try them out and see what exactly it does or rather if the fanspeed jumps now and at what temp does it jump?
Evga at evga.com said:The following drivers/files are available for your hardware and operating system combination.
Note: If you are having difficulties downloading the driver file, please make sure you completely disable any third party download managers.
Bios Version : 62.92.16.00.22
BIOS Date : 11/30/2007
Bios File : N802 Update 1.0.zip (FTP / HTTP)
Notes :
EVGA 8800GT Superclocked BIOS Update
This updated BIOS is only for the EVGA 8800GT SC (512-P3-N802-__)
KO and SSC versions will be posted soon
Updates are as follows:
Improves fanspeed auto sensor
Windows XP/Vista Flash Instructions
Download the appropriate update above, and extract files to a location on disk
Completely remove NVIDIA display driver from Add/Remove programs
Restart PC
Make sure no programs are running in the background, and double click update.exe from the extracted .zip file
Press Y to begin flash
After flash restart PC
Reinstall the 169.09/169.12 or later graphics driver
IMPORTANT: If running in SLI, each card needs to be flashed separately
