Bios that allows Founders Edition cards to run at 0% fan speed?
gsilver
This is a NVidia GTX 1070
I recently replaced the stock cooler with an Arctic Accelero Xtreme III, and it seems to allow a minimum fan speed of 27%.
While that's reasonably quiet, I really want a silent-at-idle build, so it's a bit disappointing.
Is there any way to do this, such as via a bios update?
My motherboard's fan headers are pretty much full, so that isn't really an option.
Edit:
Actually... The fan speed slider doesn't seem to change fan speed at all?
Something's not right here...
Edit 2:
I just combined my side fans and exhaust to the same header and put the GPU fans on the one that I opened up, then put the sensor to adjust the fan curve based on CPU temperature.
Near silent at idle now. Temps still look good.
What card? Those with GP102, such as the 1080 Ti, will not allow 0% fan speed even with a BIOS modification. To get around that you can try plugging the fans into a motherboard header and controlling it that way, instead.
Sorry for not specifying.
It's a GTX 1070
You can try a BIOS from one of the reference EVGA boards that use the ACX or iCX cooler. I'm pretty sure the fans go down to 0% on those.
08G-P4-5171-KR = EVGA GTX 1070 GAMING ACX 3.0 Black Edition
08G-P4-5173-KR = EVGA GTX 1070 SC GAMING ACX 3.0 Black Edition (88 MHz higher base clock than OEM)
08G-P4-6171-KR = EVGA GTX 1070 GAMING ACX 3.0 (Thermal pad update)
08G-P4-6173-KR = EVGA GTX 1070 SC GAMING ACX 3.0 (Thermal pad update, 88 MHz higher base clock than OEM)
08G-P4-6571-KR = EVGA GTX 1070 GAMING iCX
08G-P4-6573-KR = EVGA GTX 1070 SC2 GAMING iCX (88 MHz higher base clock than OEM)
hi gsilver!
I'm having a similar problem. Did you find a solution?
Thank you and sorry for my bad English
Attila
I'm pretty sure it's designed to run like that. You can get a slient case to muffle the sound or put your case a few feet away.
bioses are locked down hard with those. no way to do what you want short of hooking them up to your mobo.
