Just curious if this is a rule.
If I have a 200mm fan running at 2000RPM will it deliver the same airflow as a 120mm fan at a higher RPM and cause less noise?
Also, undervolting a 12v fan is easy enough, but what about AC fans? I've been reading around and people say you shouldn't do it. Is there credibility in that?
Thanks.
Thanks.
