markland556
- Dec 24, 2004
wel i restarted my computer and now it wont work. It says "A disk read error has occured" press Ctrl+Alt+Del to continue.
It worked fine before.
If i try to boot my windows CD it wont go past the part where it says press any key. The screen turns black and stays there. If i unhook the SATA drive with windows on it, it goes to the CD as it should, but then i cant really do anything useful.
Any help woud be awsome.
