BFG gtx 285 for 274 at BB BM
Discussion in '[H]ot|DEALS' started by groebuck, Jun 2, 2009.
  1. groebuck
    groebuck 2[H]4U
    2,468
    Mar 9, 2000
    I just got a BFG gtx285 for 274.99 it did not say sale just marked 274.99..funny thing is it was right next to a 275 for 289 lol.
  2. PClark99
    PClark99 2[H]4U
    2,824
    May 3, 2000
    Definitely YMMV.
    I was in BB in Holmdel, NJ yesterday, they had one for $354.99
  3. turbolude
    turbolude Gawd
    784
    Jan 23, 2005
    damn im about to check my local bb in nj
  4. UnclePauly09
    UnclePauly09 Gawd
    523
    Feb 28, 2009
    It was probably sitting next to a 9800gt 1gb for 249 usd also. BB has the most screwed up prices. If I see someone shopping the GPU's I ALWAYS let them know what's up. Good Samaritan I is.
  5. groebuck
    groebuck 2[H]4U
    2,468
    Mar 9, 2000
    lol nah they seem to be closing out the 9800's They had a 260 for 174 or the 285 for 274
  6. keldegar
    keldegar Limp Gawd
    339
    Dec 11, 2006
    saw it at my local BB for $306.48... list price was $374.99.
    Maybe they'll accept the 10% off mover's coupon.
  7. seanmcd
    seanmcd [H]ard|Gawd
    1,430
    Jan 20, 2003
    Yep I was actually @ BB today to buy the GTX275 @ $289 but found the GTX285 for $279 !!
  8. seanmcd
    seanmcd [H]ard|Gawd
    1,430
    Jan 20, 2003
    ** warning - these cards MAY have an incorrect bios from the factory
    Found two other website forums discussing this same issue:
    crap - so I try out the card, runs DOD Source just fine... then to see what it does with 3Dmark2k6... well it's making all kinds of high pitched sounds. About halfway through the benchmarks the card crashes...
    I crank up GPU-Z and find the GPU is at 694MHz, memory at 1296MHz, and Shaders at 1584MHz!
    It should be running at 666 for the GPU, 1242 for the memory, and 1512 for the shaders! now what ?
  9. Blazestorm
    Blazestorm [H]ardness Supreme
    6,940
    Jan 17, 2007
  10. seanmcd
    seanmcd [H]ard|Gawd
    1,430
    Jan 20, 2003
    if it were actually stable without having to underclock it down to OC levels, that might be the case, but it's not. Basically I'm going to have to take it back and pay $10 more to get a 275... which is sad. I guess the other option is to RMA it, but I would rather not have to mess with that unless they would send me a card first. I called their tech support (BFG) - soon as I described the clock speed being too high he was like "...Ohhhh ok let me setup an RMA for you" as if he knew of the issue. I asked if they could just send me a link to the right BIOS file and he said no.
  11. alik4041
    alik4041 [H]ard|Gawd
    1,304
    Jul 6, 2005
    If I were you I would play it smart. Use rivatuner, clock it down to default 285 speeds, then benchmark for stability. If stable, then flash the card with a normal 285 bios. I wouldn't take it back unless it completely was not stable. Heck even if I had to go down a couple notches then stock, I would still keep it if it were stable. It would outperform the 275.
  12. SBB
    SBB Limp Gawd
    132
    May 30, 2009
    Yeah just clock it down, test then flash it, that's all they'll do if you send it back anyway
    On a side note i'd probably still rather have the $220-240 GTX 280s that are about, just for best bang per buck
  13. Fluke
    Fluke Limp Gawd
    493
    Mar 22, 2000
    This happened to me on a 280 I got from Newegg. It was the set at the OC of the next higher card in the 280 lineup. Not an incorrect bios, just a better clock. I figured OK, more performance for the money and its rock stable. Whats the problem?
  14. seanmcd
    seanmcd [H]ard|Gawd
    1,430
    Jan 20, 2003
    Well if I could get a bios from someone I trusted to have the correct one I would consider that. I also considered editing the bios speeds myself but who knows what kind of memory tweaks they might have done for either bios (they may be different?)
    The problem is it's not stable unless underclocked to the speed is supposed to run at...
    Sidenote: although they won't send me a BIOS :) - BFG suppurt gets two thumbs up for answering the phone immediately on a Saturday, and replying to emails immediately on a Sunday!!
  15. Fluke
    Fluke Limp Gawd
    493
    Mar 22, 2000
    Sorry. Missed the part where you said it crashes. 6 am is too early. Don't do a standard RMA. You'll probably get a refurb back. Return to BB or post to the video card section here. A BFG rep reads it and he could get you a new replacement.
    Also, don't downclock to see if it's stable. I got a bad 7900GTX once and did that. It fixed the problem but when I tried to RMA and told BFG tech support I had downclocked, they voided my warranty. On a brand new card! Asked for the supervisor and the guy said that's who said to void my warranty.
  16. alik4041
    1,304
    Jul 6, 2005
    I disagree. He said that he got a card with a DIFFERENT more advanced bios then what it should have arrived with. Meaning that if he downclocks the card to what it SHOULD have, he should be fine...and they would have no argument. You have to remember that he got the card for a steal. Again downclock the card before flashing...this is for your test purpose only and they have no way of telling you downclocked it. Bios should be easy to find...i'll help you out with a search of my own.
  17. seanmcd
    seanmcd [H]ard|Gawd
    1,430
    Jan 20, 2003
    thanks but too late - I took it back to BB. I just got a 275 instead, which was what I intended to get in the first place :) I modified my 8800 GTS bios in the past and I know what I'm doing, but just wasn't interested in playing around with it. I really should have been patient and RMA'd it... but oh well
  18. fam
    fam Limp Gawd
    417
    Feb 11, 2006
    proof of gtx260 for cheapness below (sorry was taken on phone)
    [​IMG]
    [​IMG]
  19. seanmcd
    seanmcd [H]ard|Gawd
    1,430
    Jan 20, 2003
    dangit, couldn't help myself. Took the 275 back and tried another 285 (it is still on clearance at my BB). I figured this time I'd just RMA it...
    Again it was clocked too high, BUT this time it's rock solid. Tortured it with furmark for a few hours, then looped a maxed out 3dmark2k6 overnight without any issues. w00t!
  20. groebuck
    groebuck 2[H]4U
    2,468
    Mar 9, 2000
    the clearance one is the 285OC so it will be overclocked. gratz! I took mine back yesterday I am doing 260 sli ! woot
  21. seanmcd
    seanmcd [H]ard|Gawd
    1,430
    Jan 20, 2003
    right but it's an OC version that's actually running at the OC2 card speeds by default - 694MHz, memory at 1296MHz, and Shaders at 1584MHz!
  22. ezrem
    ezrem Limp Gawd
    225
    Mar 14, 2000
    I got one of these from Best Buy as well. Isn't quite stable at the stock clocks, as I was getting not quite crashes to desktop (game stays running, windows gives the "display driver failed but successfully restarted" message). While annoying, I guess it's better than the game flat out crashing and having me lose all of my progress.
    I dropped the clock to 680MHz using EVGA Precision (because it actually works in Win7) and it doesn't crash at all now. I haven't tried to push it any higher, but it's silky smooth already anyway. I'm wondering if I should just be happy with this or not?
  23. DocSavage
    DocSavage 2[H]4U
    2,409
    Dec 18, 2002
    I too bought one of those BFG 285OC's at Best Buy which came way overclocked at 694MHz, and thought I'd throw in my experience.
    Games would lock up instantly. Using EVGA Precision, I underclocked it to the 666MHz as listed on the box, but overheated and crashed some 40 minutes into a game. The card does seem to run perfect at stock 285 speeds of 648Mhz core at temperatures of up to 89c.
    What I like about the card. On my Q6600@3.3Ghz and 2560x1600 resolution, I am able to run at 4xAA and very high settings with complete smoothness in every game I've tried. This is even running the card at it's 648Mhz speed.
    What I really don't like about the card are its idle temperatures of 66c. I've read that these cards stay in performance mode if you have dual monitors, but this just seems ridiculous as I leave my pc on 24/7 and don't want to waste money I don't have to on electricity.
    I just don't like the idea of having a card that requires underclocking to remain stable. I could RMA it, but I don't really want someone else's returned card either. I'll probably just take it back to Best Buy tomorrow.
  24. ezrem
    ezrem Limp Gawd
    225
    Mar 14, 2000
    Hmm, that's quite a bit warmer than mine.
    I'm at 680MHz as I said in the earlier post, and I idle around 58C. Load has never topped 85-86, even when the card was running at 694MHz as it came out of the box.
  25. seanmcd
    seanmcd [H]ard|Gawd
    1,430
    Jan 20, 2003
    My second card is pretty stable at the incorrect speeds. I did 4 hours of furmark stability test at my native res with settings jacked up before apparently rebooting :) Temps max out at 85-86 during furmark.
    It did 13 hours of 3Dmark 2006 looping, with all settings maxed out (native res and filtering/aa as high as it will go) before 3dmark crashed.
    I need to try those two scenarios again withOUT overclocking my CPU as it runs at 8*500
    I cannot get it to crash or do anything wrong while playing Crysis Warhead dx10 or DOD Source... So I've registered this card and will keep it. First sign of it crashing during regular gameplay I will RMA it.
  26. ezrem
    ezrem Limp Gawd
    225
    Mar 14, 2000
    This card is so weird. I can play all kinds of Prototype or NWN2 at 680MHz but as soon as I try TF2, nothing but crashes. I reduced everything down to stock clocks, even.
    Back it goes, I guess.
  27. fam
    fam Limp Gawd
    417
    Feb 11, 2006
    wonder why its on clearance ;-)
