Well it finally went abobe 75 degrees around here. it hit close to 85.
usoing HDR demo. Didn't see any artifacts. I think if it hit 95 degrees
in my room the temps of the gpu would probably hit 95c to 100c
Here are somt temps in a HOT room.
400/1000
ambient temp: 60c
gpu core: 89c - 90c
room temp 29c
ambient temp: 61c
gpu core: 90c - 91c
room temp: 30c
heat is something I cant avoid. So if its hot I have to run it in the heat.
400/1000
ambient temp: 60c
gpu core: 89c - 90c
room temp 29c
ambient temp: 61c
gpu core: 90c - 91c
room temp: 30c
