BFG 5900NU fan just too whiny!
heyheyhey
Well, I've been happy until now, and now I just can't take it anymore. The top right fan on my BFG 5900NU is running at a higher RPM than the one on the bottom left (records from my extremly detailed stick-fingernail-in-fans and compare the whine of each), so it must be running at a higher voltage, as it is connected to a 2 pin connecter at the top left of the card, and the bottom left fan connected to the same 2 pin type connecter in the bottom left. So now my question. Any way to shut this thing up? I would unplug it, but I'm concerned about temperatures, and the thought of it being unplugged would bug me to no end. Is it possible to run both fans off of one power connecter? I know my soldering skills aren't exactly up to par, but I'm pretty sure I know how to get two wires together :p
If not, is there anyother way?
@trapine
yup RMA and buy a 9800Pro for a few dollars more no noise better performance.
Or welcome to the noice that is the FX:p J/K
don's flame proof fanboy jacket and waits to be assulted by nividia mafia
But seriously :D have you thought about trying an after market cooler maybe;)
DizzySHK
i got myself a vantc iceberq pro and ocz bga copper ramsinks..
i have added zalman fanmate to the cooler.
it is near silent with about 45c idle and around 75 load.
Badger_sly
RMA it to BFG. They'll take care of you pretty quick.
Also, you're the first person I've heard of that had a problem with their cooler. Bad for you, but great quality record for them.
heyheyhey
This things faster than my 9800P ever was... and I doubt I can RMA since I hacked the BIOS. Guess I'm SOL.
zandor
Nah, you can always get aftermarket cooling.
How about water + pelt?
heyheyhey
I am water cooling my box soon.. may have to pick up a video card block as well... thats a good idea.
jyi786
Do you have this on a 5900NU?
