Only time I have issues with scoping is when using a bipod. Sometimes I'll reload and it won't re-scope automatically ( I wish they hadn't added that feature in the first place). I use toggle-scoping though.
What mouse are you using OP? I have the same problem sometimes.
I'm using a Logitech G9x by the way.
I know exactly what you're experiencing OP, I'm using a Logitech G500 and it used to do the same thing. Fiddling around with Raw Mouse Input seemed to fix it for me. It really pissed me off for quite some time, as it made shooting pretty much impossible.
