BF3 CACHES ram - it means that what is being "used" is not necessarily being used.
1 Monitor - you don't need more than 2gb.
cached is the same as used that way it doesn't need to load into memory and i would rather have that.
I have a 3GB card and I haven't been able to directly compare the performance/visual differences between 2GB and 3GB in BF3, but I know that I regularly exceed 2GB of usage in several games and I'm only gaming at 1080p, which makes me wonder why so many people are saying that 2GB is plenty for every game unless you are multi-monitor.
Yes. In BF3 I often go above 2GB according the the MSI Afterburner OSD. In Skyrim with the mods I'm using I am almost always above 3GB. Again, I'm at 1080p. Also in Metro 2033 I am almost constantly above 2GB. However, I don't know how this affects performance.Got any examples? There are plenty of [H] reviews that show the 2GB GTX 680 keeping up with the 3GB 7970 even at high resolutions/multi-monitor.
For those of you with 4gb cards what is your vram usage at 2560x1600 with everything max
This is an excellent question filter. Will the 4GB of VRAM exceed 2.32GB of usage if the game knows there is VRAM to spare. I want to know the answer to this also
I have two gigs of ram and windows annoyingly pops up every 20 minutes during bf3 saying low vram. Of course this is with windows 7 pro with everything turned up in windows.
So, yea 2 gigs is not enough to avoid annoying win messages. Have to set bf3 to turn off window's desktop prettiness for them to stop popping up....
That's a bug. It will pop up even in games that use next to no VRAM.
One annoying ass bug if it is.
I was playing bf3 as usual tonight just to check it out (with windows settings all up) and it was hovering around 1 gig at 1080p. No buggy pop ups, however.
Yes it is. I eventually turned off Aero on most of my games (via the shortcut) so my second monitor would display correctly in full screen games, and that got rid of the pop up as well. Used to really annoy me in MP3. I thought I read somewhere that one of the newer drivers (probably a beta) fixed it, but I never followed up on it.
How can you be above 3GB when you only have 3GB?
i saw 1.7gb used on one video card and 1.05GB used on one of them at the same time which really confused me when i was using 2 1GB 6870's in crossfire so im wondering if windows is caching it some where?
In Windows 7/Vista go to Start menu. Go to Accessories. Locate the command prompt shortcut and hover mouse over it. Right Click on the shortcut then select Run as Administrator.
* In the command prompt type this exactly:
bcdedit /set increaseuserva 2500 or 4500 depending on the amount of memory you have and hit enter.
* Make sure you get a message back confirming the change was made. To verify the entry is there you can type just bcdedit, hit enter, and you should see the entry now listed.
* Then close the command prompt. You just told Win 7/Vista to increase your user virtual address (userva) space to 2500MB or 4500MB.
* Changes take effect on reboot.
Now reboot the PC because Windows needs to set the userva at 2500 or 4500 which will only happen after startup.
If you skip any step it will not work. When you have rebooted you should be good to go. Run the game as normal with the original game shortcut.
TO UNDO THE CHANGES
Open command prompt as administrator and type: bcdedit /deletevalue increaseuserva. That deletes the entry.
Reboot to reverse the process.
Anyhow, this worked for me... been playing BF3 three days in a row with zero crashing or directx errors.
Cheers,
Stephen
I will post screenshots.
I'm not doubting that's what you're seeing but I'm assuming you know basic math so I'm assuming you know it's mathematically impossible to use more than 3gb of VRAM if you only have 3gb. What that means is those readings are inaccurate and don't mean anything.
I'm going off the memory usage on the MSI Afterburner OSD readings. Are those accurate?
Their conclusion: no game on earth needs more than 2GB ram maxed-out on 2560 resolution. And many games handled 3240x1920 + AA without a hitch with only 2GB to work with, so there's some room for growth in the 2GB cards as well.
The only case where you will benefit from 4GB ram is if you plan on running mufti-monitor with SLI.
1920 x 1080 Arma 2 Day Z mod used 2917 mb of Video Ram on my PC with my 7970.
Just saying.
Also I used msi after burner to see the amount of ram used.
Are there any tools which give a reliably accurate measurement of real-time VRAM usage? If not, then all speculation on the subject is pointless...
