I can't believe this but yes. I get normal 3D06 scores around 6200-6300 depending on my oc very mild 2.2 on an opty 170. BF2 is just slightly jittery or something and my FPS is the same REGARDLESS of settings around 50-90 fps but sometimes in the 40s! at 1280x1024. I noticed on my Core Center that my V core fluctuates b/w 1.32-1.41! I had to use an Antec 350 watt b/c both my Seasonic SLI and Antec Sli busted. I am using and APC backups and I had a SN25P run on the same power supply for 6 months without a hiccup. I need to reformat I think b/c I just did a repair install on this HD after it had run on another MSI SLI mobo a while back. just venting really but if anyone has a guess about the voltage Holla back?
