I"ll make this simple because I'm sure everybody has had this problem I just can't figure out the answer. I want Left Shift as my crouch key, yet I can't and it drives me crazy. Ideas?
You can't because it's being used by another *function*...you'll have to find what it's being used for, then bind it to a key on your keyboard that the game is not using, then bind shift to what your plan is for it.
binding keys in BF 2 is a total hellish nightmare.....just takes patience
Here's what ya' do.
Start the game...go into the options......change which ever function is being used to a *period* or some key that is not already bound.
Once that happens then you can bind*crouch* to shift............
Hmmm, shift is your RUN key........now that we know that, follow the procedure above...good luck!
