How do I find the cache folder?
Clearing Shader Optimizations: When you change the graphical settings or install a new patch, BF2 attempts to optimize the shaders used in the game for the best performance on your particular hardware. These optimized files are stored in your \Documents and Settings\[username]\My Documents\Battlefield 2\mods\bf2\cache\ directory in XP or \[username]\Documents\Battlefield 2\mods\bf2\cache\ in Vista. If you've changed your settings several times, I recommend you finalize your changes, close BF2, go to the above directory and delete everything under the \cache\ directory. The next time you start the game and play single or multiplayer, your shaders will be optimized again. Close BF2 one more time, defragment your hard drive, and now things should be much smoother and load much faster the next time you go to play BF2.
Dont you have to run as admin right or something like that?
Right click, run as admin or in properties.
Are you installing 1.4 or 1.41? 1.41 was the last patch before 1.5 and should be the one you're installing first, not 1.4.
Installed BF2
Installed full patch 1.4
Installed full patch 1.5
When I click on BF2 to play the screen goes black like it's about to load but then it goes back to the desktop. I am using Vista and need help.![]()
Ah, I know what the issue is.I had the exact same problem last year until I figured out that the game was trying to launch with the wrong refresh rate, which crashes straight back to the desktop without any error messages. Browse to \Documents\Battlefield 2\Profiles\Default (as well as \Documents\Battlefield 2\Profiles\0001, if present) and open the Video.con file in Notepad. Edit the VideoSettings.setResolution line to something such as 800x600@60Hz. Save and launch Battlefield 2, it should do the trick!
-R
resolution and refreshrate are big killers of that game
I think you are right. On my two Win 7 64-bit machines with exact parts:
1. PC to Dell S2409W = works like a charm
2. PC to Onkyo Receiver to Projector = Game will not launch
Oh well, I tried every trick on the net last night and it won't load. I get the renxxxx.dll driver failure every time. What's funny is that CSS, the game that refuses to die, plays perfect on my projector. Too funny.
Ok, I grabbed the S2409W and plugged it in the machine connected to my projector. Both games booted like the other machine did. I went into both games and changed the resolution to match my projector. I then unplugged the monitor and replugged in my projector. The good: BF2142 works, yea!!!. The bad: BF2 still will not boot. Both games have the same tweaks noted above, but for some reason BF2 does not like the refresh rate of my projector.
What's funny is I can unplug the projector and plug in the S2409W and BF2 boots instantly. Unplug it and replug in the projector and the game won't boot.
However, when typing this what I should try is to boot the game with the S2409W and while the game is running, switch the plug over to the projector. Hmm.
