I bought the 2 boosters long ago, as well as special forces.If I remember correctly, it was BF2>Patch 1.5>BF2: SF> Patch 1.5
Patch 1.5 has the 2 other expansion if you don't have the BF2: Special Forces
Hope this helps
I think everybody has their own "voodoo" about install order of BF2. my order is bf2, special forces, 1.41 full patch then 1.5. This makes the most sense for me because obviously you start with bf2, then sf because it was out before 1.41. I install the full 1.41 patch because this is how the game was played for a long time before 1.5. And because most people just patched to 1.5 and you didn't need a clean install, it just makes sense to do it in this order.
This is what I did (like I posted earlier). Now i'm having issues with punkbuster not updating. Went to PB website and tried to manually update. Supposed to have done it right, but apparently not as I've been kicked from several servers now.Except you have to install 1.41 first because 1.5 is just an incremental patch. The correct order is
BF2
1.41
SF
1.41
1.5
Any other order won't get your game fully patched and up to date.
BF2
1.41
SF
1.41
1.5
Why would you need to do 1.41 before SF and then after?
SF auto-patches BF2 to 1.03 prior to installing.
I am going to try BF2, SF, 1.41, then 1.5 and see if that works for me. I skipped SF last time since I didn't feel like adding more time to the install, and my current install has really messed up textures for some reason.
