get pbupdate from www.evenbalance.com.. or maybe you got banned cuz of your mouth..
I've done that already, but thanks.
Awesome!
No installation problem on Win7 64-bit. Installed BF2, SF, 1.41 patch, and 1.5 patch.
CD check is gone
2560x1600 WS max settings
Had problems with PB, fixed by downloading and running pbsvc.exe and pbsetup.exe
Played for about an hour, didn't notice any problems.
I have the standard shortcut... ony thing I have is a "+restart" which disables the intro vids... my res and everything is enabled in-game...
yea and most mirrors are still being hammered... Fileplanet Founder's Club FTW!
"C:\Program Files (x86)\EA GAMES\Battlefield 2\BF2.exe" +menu 1 +restart 1 +widescreen 1 +szx 1680 +szy 1050
I hate those guys, but there still owning me. I aint really that good but i am good enough to have fun, i guess thats what matters most.BY FAR the best part about this patch is owning all the guys who jump and go prone EVERY time they see somebody.
I fixed my CTD issue I had to disable SLI - apperrantly 190.62 + bf2 1.5 under Windows 7 64bit are incompatible atm, single card runs flawless
I spoke too soon
*snip*
anyone with Windows 7 64bit getting
snip
okay after installing and patching to 1.41 bf2.exe is roughly 7mb. I'm going to kick off 1.5 and see what happens.
*update*
after installing 1.5 the size of the executable went from about 7,347 KB to 6,403 KB interesting....
*update 2*
okay everything works..strange
LOL, this game really does not need a whole lot to run maxed. If you really wanna see this fly, disable the max frame rate which is set to 100FPS.
I spoke too soon
SNIP
make sure your remove all of the falcon presets or controller presents in the secondary column.Hmm for some reason after the patch I can't pitch up or down with my joystick.
Desktop CTD
if your running Vista x64 or WIn 7 64 check your event viewer for this:
A request to disable the Desktop Window Manager was made by process (BF2.exe)
The Desktop Window Manager was unable to start because composition was disabled by a running application
try disabling desktop composition under compatibility mode within the BF2 shortcut.
Got a few hours of playtime in last night. Oh, the memories. Still know how to fly them heli's & jets!
I will say, the thing looks horribly dated, even at 2560x1600, but so dang fun. And it runs so smooth!
start>games>bf2>rightclick but theres no customize option? Am I missing something under W7? In vista game explorer you could customize game shortcuts, etc. I dont see that feature under W7 games explorer
I just finished downloading the patch and all i got was a 1.92 GB windows shell common dll file
so i tried again on my laptop and got the same thing !
How do i open it ?
How do i open it ?
That's odd, it's an .exe for me.
