Hello Folks,
Recently, my system simply turns off in the middle of work and I haven't been able to get it back to work -- even to post, let alone anything to show up on monitor.
Here is my system config:
PSU: CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply
MoBo: DFI LP UT X58-T3eH8 LGA 1366 Intel X58 ATX Intel Motherboard
RAM: 6GB (3 sticks)
Graphic: Evga 260
Monitor: 2 years old Dell 222209WA.
Second HD drive is hooked onto system also, but only as a storage drive.
Complete system is roughly two years old and running Windows 7 X64
Not sure what's going on with my system. In the middle of work, my system just turned off.
Steps Taken so far:
Upon attempt to reboot, first couple times, nothing happened, but there after, it fires up. However, nothing appears on monitor.
Switched to a spare graphic card, reboot again, but nothing appear on monitor.still.
Took out main hard disc drive that contain OS, hooked onto a different system via USB external enclosure, showed up OK, So I am assuming, it is working properly.
With the help of fellow HardForum members limitedaccess, dioxholster, Danny, and Enginurd, did the following, but still no solution:
1. When first turn on Monitor to double check OSD, it displays "MESSAGE entering power save mode" and the "Dell 222209WA", nothing else. Is this what OSD refers to? There are no Vertical color bars displayed whatsoever.
2. Confirmed that the led light, "reset" and power shut off buttons come on when hooked to and turned on power system.
3. Took lithium battery off, then reset jumpers to pins 2&3. After over a minute or so, put back the battery, and set jumpers back to default position (pins 1&2). Replug, power cord, Turned on system again, but still nothing display on monitor. (System still hooked up with the spare graphic card).
4. Cycled through memory sticks:
Took the first two (furthest from the CPU), then use that first one placed in 2nd, then third slots, with each reboot in between, nothing appears on monitor.
Used 2nd stick, placed in first, 2nd, third mem slots, with reboots in between, nothing appear on monitor either.
Used third stick, placed in firs, 2nd, 3rd slot, with reboots in between, nothing either.
5. Followed Danny's suggestions on "Back to basics....A Barebones bench test"
Reseated the old CPU, still nothing solved.
6. Recently got a hold of an identical brand new CPU to replace the old CPU, but still not posting.
At this point, really not sure what's happening. Any and all thoughts on this would be much appreciated.
What's left is whether the MO is working or not. Once plugged in the power supply and turned system on, the led light by the memory slots comes on as well as the reset and power buttons on the MO. All the fans attached to the system also come alive when turned "On".
What method(s), if any, are there to test for workmanship of the MO?
Thank you in advance.
RAM: 6GB (3 sticks)
Graphic: Evga 260
Steps Taken so far:
