hokatichenci
- Oct 28, 2004
Alright, my boss has tasked me and the other tech with building a high performance storage solution.
The only specifications for the system are:
-full redundancy
-hot swap
-high-bandwidth interconnect desirable (My assumption is he wants 10-20gbit capability incase we ever go infiniband on any given cluster we have).
Now so far I've sort of at a very basic level compared Apple to Homebrew, with the homebrew having:
Areca 1260/1270
WD RE2 500gb or Seagate 500gb
Some generic hotswap cages
I'm estimating the base cost to be around $5000 for homebrew, not including the case/cpu/etc... Now my questions for homebrewing are:
Where can we get a like 4U case that has a ton of 5.25" slots that I can just jam pack full with sata hot swap cages? What sort of power supply should I be looking at for something that'll run 16-24 drives? Should I run multiple power supplies?
Now on to the Apple Xserve Xraid or whatever it is they call it.
$13000 for 7tb. Plus a fibre channel card which is probably what, $500? Has anybody used these before? Experience? Worth the money, are there better options for non-homebrewed?
Thanks a lot for any input.
-full redundancy
-hot swap
Areca 1260/1270
