So I want to play my PC games (computer is upstairs in my office) in the basement on my HDTV.
Sounds simple right? Thought I would drill a hole in one of the walls (at an angle) towards the basement floor and run a displayport to HDMI cable, ethernet cable, USB cable, etc. through there.
Turns out that the way my house is built the basement is only under HALF of the house, so basically I drilled a hole into the crawl space and there is no way to get in there to run the cables.
So what are my options?
I noticed that there is a coaxial cable in the basement. Is there some kind of coaxial cable/ethernet adapter I can purchase so I can at least hook up a Steam Link in the basement?
I looked into switches but from my understanding you need to hook up an ethenet cable to it.
What if I got a second modem and hooked up the coaxial cable in the basement to it? Would WOW charge my double to have another modem in the house?
What do you guys think I should do? The whole office I think is over the crawl space of the house.
