scharfshutze009
- May 22, 2010
I have a 12U openframe post server rack that I want to move from a building in one city to a building in another. The rack can hold up to 596.7 lbs and the total weight of the equipment has been calculated to about 350 lbs, but what is the best way to tranport it. Why can't I use a 15' Uhaul truck with a built-in ramp if I ratchet strap it on one side with two parallel straps and to the back of the inside of the box truck with two straps parallel even if the rails to ratchet strap around are 3' or waste high off the ground and the height of the server rack is 25.9 or slightly over 2' off the floor or ground? Why do I have to unrack the equipment to transport the equipment considering the above and that the rack has wheels? Also isnt't the equipment safer while mounted to the rack. Why heck is someone insisting that we use their mini van and ramps to get it up into that when they don't seem to know how we'll get it out once we get it to the other site?
