visionviper
- Jul 24, 2007
I am looking into taking a big jump into folding for the [H]ord and I am currently looking into setting up 10 systems with identical specs for folding. What would be the best way to take advantage of all the computing power? Setup an OS and the folding client on each computer or use each computer as a node and have a micro supercomputer thing going? I plan on using either low cost single core or dual core Athlons.
If you are wondering, these are the two processors I am looking at:
AMD LE-1640
AMD Athlon 64 X2 4000+
Should I take the dual cores over the single cores?
AMD LE-1640
